Message 1 of 9
07:53 AM
I am exporting STL files to be used with a 3D printer. There are two solids, which are exported separately and then imported into the slicer software. However, the origins are off when they are loaded into the slicer - this is an AutoCAD problem, as this problem persists across several slicer programs. The objects are aligned when exporting, but misaligned when loaded into the slicer. I found this same problem in the Fusion 360 board, but the same fix doesn't apply to AutoCAD 2014. (If this problem is fixed in the latest release we will be upgrading next week) https://forums.autodesk.com/t5/design-and-documentation/exporting-separate-stl-files-in-the-correct-... Any ideas?
