Startup Suite - how to off?
iBlachu
iBlachu
Is there any system variable through which automatic loading of programs defined in APPLOAD and Startup Suite can be turned off?
Or how can this be disabled using LISP or VBA?
ВeekeeCZ
You might use the /savemode switch to prevent them from loading.
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A
pendean
Community Legend
Community Legend
@iBlachu See the highlighted section from HELP on the topic, it's all about how you start the program session where this is a need (yes, you can have multiple sessions open too)
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A#:~:text=...
Here is a golden-oldie tip that is the exact ask as yours from what I can tell if you want to try something else
https://www.cadtutor.net/forum/topic/32431-is-there-a-way-to-remove-all-lsp-from-the-startup-suite-v...
