AutoCAD Forum
Starting AutoCad 2015
3 REPLIES 3
231 Views, 3 Replies
I downloaded the autocad 2015 and for some reason, there was no shortcut on the desktop. I tried going into the file by going (c:) > Autodesk > AutoCAD 2015 English Win 64bit. Where or what Icon do i need to find to open up autocad?
3 REPLIES 3
downloading is not the same as Installing
are you sure you went through the install process?
well I did download the browser version and I did install it. one of the
problem was after installation of manager, tools, and side dtuff was done,
it was giving me the option of installing autocad 2015, autodesk 360, and 1
another. autocad 2015 cannot be checked as it was already installed in
program files. so now im just clean uninstalling all autodesk programs and
starting from scratch.
edwin.prakoso
Have you managed to solve this? It looks like you installed AutoCAD 2015 before, and it wasn't successfully uninstalled.
If that is the case, you need to uninstall it using Microsoft FixIt: https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Cheers,
Edwin Prakoso
Forma Design Contest
