Start Up Script
Start Up Script
PiscesBob
Start Up Script
PiscesBob
Is there a start-up script that will put the quick access toolbar below the ribbon? After I installed a weld app now AutoCad 2022.1.1 starts with the quick access toolbar above the ribbon.  It didn't used to do this.  The script would be located in my desktop shortcut like this for my startup script: /b setupx.scr
pisces-aquarius
cadffm
You can add the command to a ACADDOC.lsp
Or just the Script load statement.
(command "_.SCRIPT" "D:\\Test\\myscript.lsp")
Sebastian
j.palmeL29YX
Place your QAT below the Ribbon - see image 1.png. Then save this configuration as a new workspace (or overwrite an existing) - see image 2.png.
Additional you can customize your command line startup of the program using the /w switch to set your new workspace as the default workspace.
Jürgen Palme
