Start Tab - Recent files
Message 1 of 14
Can anyone tell me if you are limited to 9 files showing on the Recent files on the Start Tab - or is there any way to get to see more - there's a lot of extra space on the screen (28" 4k monitor) - could easily show 15?????
Replies (13)
Message 2 of 14
RobDraw
If I remember correctly, AutoCAD tells you the max is nine.
Rob
Message 3 of 14
Changed the Options - Open & Save - Application Menu number - didn't change
anything until I opened a new drawing - then all change - weird. Now I have
15 recents on Start Tab.
Cheers
Peter
Message 4 of 14
RobDraw
Is that the max.? I thought it was nine.
Rob
Message 5 of 14
Any number up to 50 it would seem - it was opening that other drawing that
altered the number showing - why I don't know but it works.
Peter
Message 6 of 14
Valentin_CAD
For clarification:  In the OPTIONS dialog under "Open and Save"
  • File Open - Controls settings that relate to recently used files and open files.  Valid values are 0 to 9. (These are the files you see when you File >Open)
  • Application Menu - this number controls the number of recently used files listed in the application menu’s Recent Documents quick menu. Valid values are 0 to 50. (These are the files you see when you click on the Autodesk Logo on the top left)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 7 of 14
pendean
Community Legend
Community Legend
Message 8 of 14
Refer attached screenshot
Message 9 of 14
Don't know anything other than what I said earlier but below screenshot is how things are working now.
Message 10 of 14
vinodkl
Hi @Anonymous
I am able to confirm that, increasing the number of recent files in the application menu does increase the no of recent files in the File menu. Works well in AutoCAD 2018. But need to restart AutoCAD to reflect these changes 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 11 of 14
anthonyG4LPS
What about clearing the list of recent drawings in one shot, instead of clicking one by one? Is there a Variable Mode for that?
Message 13 of 14
This problem has all been solved with AutoCAD LT 2024 - I now have 40 recent thumbnails on my screen - check the attached screenshot.
Message 14 of 14
pendean
Community Legend
Community Legend
... with a couple of sorting options to boot (all AutoCAD2024 variants)
