Start Menu Truncated
I was considering Autocd 2016 subscription & downloaded the trial version. When I first opened the program the Start Screen was trucncated. Autocad reccomends setting the dpi setting to 100% to solve this problem.  I use a an Apple 30" monitor with resolution at 2560x1600 & I set the DPI at 131% to see the icons more clearly. When I am forced to use the DPI setting at 100% the icons are so small I can barely make them out on my 55" UHD 2nd monitor. This display setting on my monitors also affect all other programs I use. I tried the Autocad 2015 trial & this was not a problem. Is Autocad going to fix this problem in Autocad 2016? I sure hope so because I can't use this program as it is.
NickEvans
This sounds like the same scaling problem I had on someones new machine a few weeks ago; it is about certain programs not handling scaling very well for UHD monitors.
I followed the advice here /http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/ and it did the trick
