Standard Detail Workflow: Embedding 'Standard Details' within Project Master/host File
Jake_PCH
Jake_PCH
I am looking to efficiently apply a library of pre-drawn 'standard details' (see screenshot below) across various projects and am looking for general guidance on achieving this.  I have attached the file of one of these details, for reference & critique.
One particular query I have so far - Is there a way of linking/embedding the paper space from a 'Standard detail' file to a Project 'master/host' file without losing the viewport positioning?
Standard detail file (paper space screenshot below);
Target project host file (paper space screenshot below)
0 Me gusta
Responder
Soluciones aceptadas (1)
402 Vistas
3 Respuestas
Respuestas (3)
pendean
Community Legend
Community Legend
@Jake_PCH wrote:
I am looking to efficiently apply a library of pre-drawn 'standard details' across various projects and am looking for general guidance on achieving this.  For example, is there a way of linking/embedding the paper space from a 'Standard detail' file to a Project 'master/host' file without losing the viewport positioning?
No, not the way you indicated: layouts cannot be referenced in different DWG files.
Layouts can be copied between DWG files using ADCENTER command, but only the content inside the layout (titleblocks, viewport outlines but not their content etc.) will copy over.
0 Me gusta
Jake_PCH
Okay, thanks for confirming.
Assuming you've got the broader gist of what I'm trying to achieve, do you know of any helpful suggestions or forum posts?
EDIT: See additional screenshot added to original post.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
@Jake_PCH wrote:
...Assuming you've got the broader gist of what I'm trying to achieve, do you know of any helpful suggestions or forum posts? ...
You could XREF the modelspace content from your 'standards' file into other files, then copy the Layout from that 'standards' file.
OR
you could get into using SSM (Sheet Set Manager): this allows you to add layouts from other DWG files to any set of a project to include as is for printing purposes.
0 Me gusta
