STANDARD CHECK AND FIX
shil143
shil143
Hi
I Have multiple Drawings ( all most layer & Style same). I need to run standards checking and fix layer/style based on *.dws file. I need to run CAD Command " Standard " each drawing. any idea how can I check multiple drawing one time and fix layers & style
0 Me gusta
Responder
1.073 Vistas
8 Respuestas
Respuestas (8)
ronjonp
Maybe THIS ?
0 Me gusta
shil143
this on ok to produce report only. i need to fix error also .
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
shil143
@pendean  This Method Only Produce Report Only. We Need to Fix Manually. But In side the CAD We Can Fix Layer to Standard Layers...If there is any Lisp to do this ...
0 Me gusta
pendean
Community Legend
Community Legend
No LISP, no 3rd party add-on as far as I can tell, the process requires so much user input its not viable.
I suspect you would have to write an overly complex VLisp/VBA/.NET program that works against a list (not a DWS) that contains all the to/from info you'd have to pre-create from all of the files and match up. Any variation in any of the outside files then you need to re-examine each and rewrite that to-from list manually, then rerun the routine.
HTH
shil143
CAD in built standard check is can check only current open drawing only. i need a lisp for multiple drawings check and fix. same as in built on not outside in start menu......
0 Me gusta
cadffm
You need a tool or a simple script to set you Layer properties,
will find what you need - but do not search for DWS.
(Some solutions can also read the the informations from your dws, but first skip this for your search)
Search for
autocad set layer properties batch
for example.
Sebastian
0 Me gusta
shil143
@cadffm agreed
0 Me gusta
