Anuncios
SSM
lee.pellegrin
SSM
lee.pellegrin
I would like to know if I create a large drawing set, and use ssm to rename tabs then remove the sheets from ssm, will there be any issues with my sheets or .dwg files? I am at a new company and my new boss is very old school, so I want to be proficient then revert it to the way that he would be good with once I rename all of my tabs.
0 Me gusta
Responder
221 Vistas
3 Respuestas
Respuestas (3)
pendean
Community Legend
Community Legend
SSM is just a cataloger of your layouts, what you do in SSM has no bearing on the physical Layouts in your DWG files.
0 Me gusta
user181
There is really a reason you couldn't do that. As long as there are no fields in your plans that reference sheet set data that would be lost after removing the sheet set.
0 Me gusta
pkolarik
Depending on your settings, drawings won't lose the SSM information even after removing them from the Sheet Set.
0 Me gusta
