SSM View Title and Callout Blocks not working
Hi, I have been assigned the task of researching SSM and setting up templates for our team to use as the new standards. I have read through and followed the entire Mastering Sheet Set Manager article series however I cannot get the View Title or Callout Blocks to work.
For the View Title, I have created a .dwt that has a three attributes all set to SheetSetPlaceholder. There is a View Number field, View Title field, and Viewport Scale field. In the Sheet Set Properties I have linked that .dwt in the "Label block for views" section. However, when I drag across a named view from the Model Views tab in SSM, if it shows up at all, the best I can get is the Placeholder Type being displayed (i.e. "ViewTitle" not ####, or ----). None of the fields work no matter what I try.
For the Callout Blocks, I have a Section Marker, and a reference Mtext note. In the marker I have a ViewNumber and SheetNumber attribute, and in the note I just have the SheetNumber. I right-click on the view I want referenced in the Sheet Views tab, then select Place Callout Block and place the block, but none of the fields work. In each block I have placed a field before the SheetNumber that references the Project Description (this displays the letter C as we produce Civil drawings), this attribute works (only once I have exploded the block). Again when the blocks are placed all that is displayed is the Placeholder Type.
I would love to understand this problem so I can fix it. Any help will be appreciated!
I have attached the files with the View Title, Section Marker, and Sheet Set Template files I am using.
