SSM Label Block Scale Field: (###) Not coming through on pdf plot
Crass
Message 1 of 11
Crass
Hello All - I periodically have this situation where when plotting a set to pdf, some or all of the fields which indicate the associated viewport scale (in this case of a detail) show as a series of ######. I plot through Sheet Set Manager. They look fine in CAD. And it seems inconsistent. I can plot twice within 10 minutes for example and in one version they'll be fine and in the second, I'll get this error. I suspect it has something to do with server communication lag but I'd love to find a solution to this once and for all. I believe others have in past recommended exploding the block but that to me negates a major benefit to having a "smart" field driving this value.
2025-03-26 17_04_49-250318_Adventure Center CD Check Set - Bluebeam Revu x64.jpg
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Replies (10)
Message 2 of 11
paullimapa
have you tried disabling background plotting?
Options>Plot and Publish>Background processing options:
Paul Li
IT Specialist
@The Office
Message 3 of 11
Crass
Thanks @paullimapa - I will try that. Do you just leave that unchecked always?
AutoCAD 2018/2021
Message 4 of 11
paullimapa
Usually if problems are encountered with plotting in the background enabled, then disable.
Paul Li
IT Specialist
@The Office
Message 5 of 11
Valentin_CAD
@Crass ,
See if editing the Field and changing to a Custom Scale help.
Other related:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 6 of 11
Crass
Hi @Valentin_CAD - Thanks for sharing these articles though I don't know if they address the particulars of this situation. In the top article I don't know how I can set  the field to object as the object, in this case the viewport, is created through the "Place on Sheet" operation through Sheet Set Manager. This is what the dialogue box looks like in the field in our block.
2025-03-27 06_36_02-Autodesk Civil 3D 2023 - [M__00_SE_Share_CADD_CADD Templates_Working_SE_Anno.dwg.jpg
AutoCAD 2018/2021
Message 7 of 11
Valentin_CAD
@Crass ,
May be.
Or try changing the Field category to Object and selecting Object and Viewport as Object type:
Emilio Valentin
Message 8 of 11
Crass
Hi @Valentin_CAD  - Yes, but when you choose object as the field you need to then select the object which is not possible in this case because as I stated above, the object (viewport) has not been created yet. Maybe I'm missing something...
I will accept the solution offered by @paullimapa as that worked (once)*, but I am interested in building a better block that doesn't present these issues to begin with.
* See further discussion below.
AutoCAD 2018/2021
Message 9 of 11
Crass
Hi @paullimapa - Originally I had accepted your suggestion to disable background plotting/printing as the solution, but it doesn't seem to work consistently. For example, on this latest plot, on some sheets within the sheet set the scales read fine. On others they do not. Is there anything else we can try? This is very frustrating.
AutoCAD 2018/2021
Message 10 of 11
paullimapa
I think I read another post recently where the solution another user did was to disable multi processing and that worked. But I’m not sure how valid that solution is since I’ve no experience with that.
Paul Li
IT Specialist
@The Office
Message 11 of 11
paullimapa
This is the post I mentioned though the issue there is a lockup when publishing
https://forums.autodesk.com/t5/autocad-forum/autocad-2022-multi-page-publish-issues/m-p/13403431#M11...
Paul Li
IT Specialist
@The Office
