SSM_ how to import only with file number?
GD.ON
GD.ON
HI,
tried to find answer and found various solution which does not work to me.
Is there any chance to import dwg to SSM WITHOUT layout name and position number?
Every time I need to adjust it manually and this drives me crazy🥴...
Any suggestions?
pendean
Community Legend
Community Legend
Nothing like that is automatic: did you set up and create/use an SSM template yet?
GD.ON
HI,
I use standard wizzard to create a set. Than I need to remove each layout name in order to keep plotted sheet name same as file.
True.
You can manipulate the import process with sheet manager. Simply dont choose to import sheet title.
GD.ON
Do you mean this:
if so, I end up with ONLY layout name:
Tried various option with this window and nothing provided desirable solution...
GD.ON
Anyone can offer solution?
