Anuncios
Splines not scaling correctly in differently scaled viewports
dseaton
dseaton
hi there,
I have come across what appears to be a bug in AutoCAD where splines are not showing at the correct scale in differently scaled viewports. However if i use 2D POLYLINE, POLYEDIT THEN SPLINED WITH ATTRIBUTES FIT / SMOOTH=CURVE FIT & LINETYPE GENERATION ENABLED then it shows correctly. see attached drawing and screen dump,
0 Me gusta
Responder
272 Vistas
2 Respuestas
Respuestas (2)
Valentin-WSP
@dseaton ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
imadHabash
Click on below image and see how it looks fine .. i open you dwg directly after downloaded . pick inside your viewport and REA ( Regenall command ) .
Imad Habash
0 Me gusta
