spell check settings
m.voss.alvine
m.voss.alvine
my spell check keeps getting turned off somehow.  is there a setting that i can run in my startup to make sure it is always on?  turn it on from the command line?
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
pendean
Community Legend
Community Legend
What do you mean by 'turned off"?
m.voss.alvine
the "check spelling" somehow becomes unchecked.
pendean
Community Legend
Community Legend
Is it a per-file problem, or system wide?
Does it turn off as you draft, or only with a restart of AutoCAD?
Is your Dictionary file damaged or missing?
m.voss.alvine
at this point i dont know when its happening.  I have noticed it every couple of weeks.  once i recheck the box, it works fine.
john.vellek
Hi @m.voss.alvine,
I haven't found a way to replicate this behavior on my side. I suspect however that you might have a corrupt dictionary file or perhaps you have a custom mapping to more than one.
Is it possible to check the path and maybe even replace the one with a file from another computer where this isn't happening?
John Vellek
