Specifying DIM line location
No aplicable
Problem with DIM and DIMLIN, won't snap on to specified dimension location. Attempted ONSNAP F3, F8 and F11. Annotative visibility was set to 1. Nothing helped.
0 Me gusta
Responder
765 Vistas
9 Respuestas
Respuestas (9)
ennujozlagam
have you try to tick any object snap modes from ddosnap. thanks
0 Me gusta
No aplicable
It is a solution that I have already tried.
0 Me gusta
No aplicable
this is something I have already tried and it didn't fix the problem
0 Me gusta
ennujozlagam
have you try to install latest updates from autodesk and see if helps. thanks
0 Me gusta
S.Faris
Post a screenshot of your OSMODE Window.
Is this a file specific issue or does this happen even in a newly created file?
SALMANUL FARIS
0 Me gusta
No aplicable
File specific, error might have been caused due to the changes I made to
the DIMSTYLE. I will update autocad and changing the DIMSTYLE to original
state and see if the problem gets fixed. Aswell as get you an image of that
OSMODE in due time.
0 Me gusta
S.Faris
Try turning ON 3DOSNAP (F4)
SALMANUL FARIS
0 Me gusta
No aplicable
All object snaps are on
0 Me gusta
Alfred.NESWADBA
depending on the point on the dimension items where you want to have an object snap working, please start command _OPTIONS ==> Drafting ==> uncheck "Ignore dimension extension lines" ... maybe this is already the solution.
If that does not help please ...
  • upload your drawing with just one dimension and draw a circle around the point where you can't use the object snap
  • start command _ABOUT and show us a screenshot from this dialog
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
