specify first corner missing
When i want to draw rectangle..this window missing....how to solve this problem?
swieciakpawel
Hello and Welcome to Autodesk forums,
Use command DSETTINGS to get the Drafting Settings window, go to "Dynamic Input" tab and there, you can set the options so that Your prompts are visible as You wish them to. For the message to appear, You need both options selected:
Alternative way is to type DYNMODE, and set the variable to 3.
Kind Regards,
Pawel
imadHabash
HI,
Just press F12.
Imad Habash
Thank you.  You fixed my problem with your 2nd option.
khodasamu11
Community Visitor
Community Visitor
its very use for me thanks
