Space bar not working as enter during command input
AutoMarcus
Message 1 of 9
AutoMarcus
Hi All
Anyone have a solution please?
when in a command and prompted for input, if I input then hit space, the command process ends, however it works if i hit enter.
I have had this issue once before, I cant seem to find any solutions online. Not sure how it was previously solved
Replies (8)
Message 2 of 9
vinodkl
Hello @AutoMarcus
Please type in the command "PICKFIRST" and check if it's set to "1". Also, try docking the command line.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 9
cadffm
you re-started your computer and it is still an issue?
Sebastian
Message 4 of 9
Kent1Cooper
Does it happen in all commands, or in only some of them?  The nature of appropriate "input" can differ greatly depending on what the command is and where you are in it.  Does that kind of difference enter into it?
Kent Cooper, AIA
Message 5 of 9
AutoMarcus
Hi Kent. it seems to be happening for all commands.
I have tried pickfirst , that was set to 1, tried restarting pc, I will have a look at resetting my profile, someone recently suggested my profile was corrupt
Message 6 of 9
jayhar
1. Check keyboard settings.
2. Try another keyboard to rule out hardware issues.
3. Update keyboard drivers.
4. Look for software conflicts, especially third-party applications.
5. Check accessibility settings.
6. Update or reinstall the command-line interface (CLI) if applicable.
7. Ensure your operating system is up to date.
8. Double-check the syntax of the command for any specific space bar requirements.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 7 of 9
Valentin_CAD
@AutoMarcus ,
Maybe a CUI reset may also work:
Or type CUI and find ENTER in the Command List; than replace the (;) under Properties/Macro with a single tap of the space bar.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 9
valonsoiglesias
Hit Key icon on command bar... select "input search options" and reduce on the very down left the option of "suggestion list delay time" to 100 (300 should be the default one)... press okay and happy days...
The problem is when you move the command bar or reduce the size, so it is let's say detached... that is where the problem comes from in cas it has started to stop working you space key...
Message 9 of 9
official_vibgyor5
Community Visitor
Community Visitor
4. Look for software conflicts using spacebar test, especially third-party applications.
Thanks a lot! It turned out to be the outdated keyboard driver. Updated it and voila it started working!!
