Someone help me to make object Visilbe pls
Can someone help me to make all objects in drawing  visible pls
so sorry because my E is too badSmiley Sad
Jonathan3891
unfreeze the layers.
Jonathan Norton
Blog | Linkedin
but some blocks still invisible.can u..?
pendean
Community Legend
Community Legend
The only items on your posted file are exploded dimensions: there is nothing else there. See attached.
use ctrl+A,u can see more thing.2 block att...
pendean
Community Legend
Community Legend
Those two blocks are damaged: use INSERT command and try to insert them, and see for yourself. Looks like you partially edited them at some point then either crashed your file or something.
The block _SMALL is blank.
The block KUroboshi is a badly drawn yellow hatched star
the block PANEL is a note tag, oval shaped.
They are attached.
