SOLPROF command with/without inner solid edge
ducvanvt
ducvanvt
I'm having some issues with using solprof command with the cylindrical solids created from mesh, so the solid is not actually a tube solid.
The problem is when I use Solprof on bigger tube the inner edges of the solid disappear, while with smaller tube they persist. I have attached the cad file here for example.
I would like to get rid of the inner edges within the boundary of the solid, just like what happened with the bigger tube. Do you know why this does not happen with the smaller tube ? and how to replicate this effect on the smaller tubes?
0 Me gusta
Responder
215 Vistas
1 Respuesta
Respuesta (1)
Johanna_Esteban
Hi @ducvanvt,
The lines are visible because each one represents a vertex of your solid, if you don't want to see them you must reshape them from circles.
Attached file with the resulting 2d in each case.
Best Regads,
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
0 Me gusta
