Solid filled objects not plotting
Solid filled objects in the drawing not plotting with the solid fill. Outline the only of the solid filled object plots.
FILL is turned on and FILLMODE is set at 1.
Can anyone help. Thanks.
pendean
Community Legend
Community Legend
Do you have HIDE on?
Or is the solid hatch/fill on a no-plot layer?
Or using something other than shademode=2D?
bhaydenEN3XT
Old thread but I was having the same issue; PDFIMPORT I'd failed to set covert solids to hatch. SHADEMODE was the answer but I had to change it from 2Dwireframe to Shaded.
Anyone know why 2D Solids don't display a layer in the properties palette?
pendean
Community Legend
Community Legend
No such issues here, see attached.
Perhaps your DWG file needs a "recovery" or that object is a custom-type (LIST command) or PROPERTIES is broken or...? Can you share?
