SOLID 3D STRECH
SOLID 3D STRECH
SOLID 3D STRECH
It's possible ?
edwin.prakoso
You can select the faces to move them, it will be similar to "solid stretch".
See the screencast video. Hold ctrl to select the faces.
https://knowledge.autodesk.com/community/screencast/0434a859-5e07-48bd-b099-5bd7efeebe8a
Cheers,
Edwin Prakoso
LyleHardin
I was going to suggest the same as Edwin. You can't use the normal STRETCH command, but you can alter the locations of parts (faces, edges, verticies) by using CTRL and picking a Face, Edge, or Vertex of the solid, then select the grip and move the cursor. Using Ortho and or point filters, you can do just about anything. There are also commands specific for these tasks in the Solids Editing ribbon and menus.
