Snapping to reference lines
plyleraaron
plyleraaron
Im new to autocad, and one really annoying aspect with dimensioning is the snapping with reference lines. I will draw a line over to specify the distance, then I hover over the end point for the reference line, then I go up to the horizontal line, but it doesnt snap to the reference line, which makes the measurement wrong. Is there any way for me to snap to that reference line, or re-dimension the line like you can in inventor?
pendean
Community Legend
Community Legend
do you have the 2020.1.2 updated installed yet? It is required.
And which running osnaps do you have on?
plyleraaron
Autocad is up to date. I was messing around with the snapping, and found that nearest is what was causing that, but then turning that off, I cant just hover near a line and have it snap right to it. I'd rather have it off since it was messing up my dimensions. I would be easier if I could roughly draw a line, then set it a distance away from another line, sorta like inventor.
vinodkl
Not sure if I understood your question, does turning on object snap tracking (toggle on/off with F11 key) works for you?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ennujozlagam
in the command prompt type DDOSNAP and set your setting. thanks
There really isn't a (good) way to do rough sketches and then parametricaly constrain them to size/shape/relative position in AutoCAD as there is in Inventor. AutoCAD does have parametric capabilities, but they don't work in quite the same way.
In AutoCAD it is best to "tell objects what size to be, and where to go" when you create them, rather than after the fact as you would in Inventor.
See this >Link< for more info on how parametrics work in AutoCAD
See this >Link< for more info on using Object Snap Tracking
Hope this helps.
