AutoCAD Forum
snap spacing of dimensions
6 REPLIES 6
hilkek
856 Views, 6 Replies
Can anyone give me information on the snap tracking of dimension spacing.
start dimensioning and when you go over a dimension you get two tracking points one on each side of the existing dimension so you can place your new dimension a specified distance apart. what turns this on and off and what controls the spacing.
6 REPLIES 6
j.palmeL29YX
in reply to: hilkek
Dimstyle (DDIM) -> Baseline spacing.
(is used by dimbaseline command and also dimspace command).
 Or you use Object snap Tracking (F11).
cadder
Jürgen Palme
hilkek
in reply to: j.palmeL29YX
Thanks, I got that now what turns it on and off and is there anyplace in the help files that describes this, not using the dimspace or dimbaseline cmds
scot-65
in reply to: hilkek
Try reviewing DIMDLI and DIMCONTINUEMODE.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
cadffm
in reply to: hilkek
You can find the answer yourself easily.
Start searching for your keyword (for example dimspace),
then you will see 3 other help pages where this can find too.
If you are using the right keywords (dimension & space) you will find them.
Sebastian
j.palmeL29YX
in reply to: hilkek
And what did you find out? It would be nice for others if you share your knowledge.
cadder
Jürgen Palme
j.palmeL29YX
in reply to: hilkek
@hilkek  schrieb:
start dimensioning and when you go over a dimension you get two tracking points one on each side of the existing dimension ...
Do you work with the plain (Vanilla) AutoCAD or do you use a vertical product (e.g. Autodesk Mechanical or similar)?
cadder
Jürgen Palme
Technology Administrators
