Snap preference
Snap preference
jason.larsenPF5AU
Snap preference
jason.larsenPF5AU
Does AutocCad have a snap preference. Or is there any future development for it.
EG I would like intersection snap to be the highest snap priority.
Then end point, perpendicular then midpoint as per attached image
cadffm
You controlling the preference by you way of cursor 😂 (and the current view / zoomlevel),
and for difficult situations you can toggle between 1. Objects and 2. snap type
by [TAB] (while Autocad detected a snap point)
Sebastian
jason.larsenPF5AU
Thanks I did not know that TAB worked for snaps.
Is tab used within any other commands ?
cadffm
Yes, it is a question of setting and situation.
There are key combinations,
https://www.google.de/url?sa=t&source=web&rct=j&url=https://damassets.autodesk.net/content/dam/estor...
TAB is also for jumps in dynamic input fields
an windows like you can jump inside dialogs from field to field..
Sebastian
tramber
Did you know that, in case of an hesitation and a need for a time to figure it out 😁, you can type, for example :
ext,cen
and press ENTER
meaning that you hesitate in between two and make your choice on moving or TABuling ?
You can also set the variable APBOX to 1 and then set APERTURE to a value of your choice.
Meaning that you will understant how Osnaps work for the first time of your life 😎
But still, there is no priority. It's all in your hand.
Kent1Cooper
The preference has always been the applicable location, on things passing through the aperture box, among the modes currently set, that is closest to the cursor location.
Kent Cooper, AIA
