Hi, I have a (metric) dwg where the objects are drawn very far from the origin point (at a surveyors mark) in the region of X = 1757499000 Y = 5920539000
When I try to use Snap Intersection between 2 lines, the snap will not work unless the line length is greater than 60mm (i.e. two 59mm lines intersecting will not snap intersection). Has anyone else seen this, and know of a fix?
BTW the lines are completely flat (used the FLATTEN command)
