Snap grips are including coincident objects
IanMcClain
IanMcClain
I have some lines / poly lines with common vertices: when I select one object's snap grip to move it, all other coincident lines are moved with it, as if I had selected all the objects.
I have not seen this behavior before today. I assume it is some system variable, but I have no idea what is causing this.
How does one stop/turn off this behavior?
Ian McClain
0 Me gusta
Responder
Soluciones aceptadas (1)
258 Vistas
2 Respuestas
Respuestas (2)
Patchy
Solución aceptada
See this symbol?
To remove it:
0 Me gusta
IanMcClain
That was is. Thank you!
DELCON allowed me to remove the constraints from objects that I had inadvertently created.
Setting the system variable in my SYSVARMONITOR to CONSTRAINTINFER=0 should prevent it in the future.
Ian McClain
0 Me gusta
