SMT cooardinates
SMT cooardinates
SMT cooardinates
Is there an AutoCAD version or add-on for X/Y coordinates  for smt part installation for pick & place machines?
Bruce
john.vellek
Hi @Anonymous,
Do you have blocks of these machines or are you looking for an application or library that contains them? Please give me some more details.
John Vellek
I'm not sure what you mean & don't know how much you know about surface
mount devices but I'll try to explain it better. SMT assembly houses require
a file for their pick & place machines to mount components (resistor &
capacitors) to the pcb. This file tells them the XY location of the part
center to a specific point on the board, it's value and it's rotation. I
know AutoCAD isn't an intelligent software but I was hoping it would have
the ability to create a file or work with outside sources to create a file.
I hope this explains it better.
Bruce
john.vellek
Hi @Anonymous,
I gotcha now. I am not sure that Autodesk has anything that would work directly but you might investigate 123d Circuits or AutoCAD Electrical
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if you looked at the links I provided. I hope they helped to answer your question.
John Vellek
I briefly looked into these sites & saw nothing of use. Thanks you for responding & I'll keep looking.
Bruce
