Smart P&IDs
Smart P&IDs
No aplicable
I have two questions on the AutoCAD program.  I have viewed the video that shows how to convert dumb P&IDs into smart AutoCAD P&IDs.  Once you convert it, can you use a viewer to access the P&ID?  Or is it only available using the AutoCAD software.  Also, can you insert hyperlinks or other type of links to access other documents outside of the P&ID?
0 Me gusta
Responder
754 Vistas
1 Respuesta
Respuesta (1)
TheCADnoob
From what ive seen If you take the P&ID out of the database it will behave like a regular DWG so you can use viewers to open look at it.
I haven't played with link in dwgs though..
CADnoob
0 Me gusta
