Anuncios
Smart leader
Smart leader
No aplicable
Is it possible in Autocad 2021 if I have a multileader, and if I have a field in it, the field could automatically get out an objects property for example a length of a line, which the leader points to? I mean if the end of the leader touches a line for example, the field automatically get the length of it. And if I change the leader to point to a different object, the field would change automatically?
0 Me gusta
Responder
Soluciones aceptadas (1)
541 Vistas
2 Respuestas
Respuestas (2)
vinodkl
Hi @Anonymous
sorry, there is no such feature in AutoCAD currently. You need to manually select the object to get its property as a field in the multileader :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
imadHabash
Solución aceptada
You may need to use an outsource lisp or plugin to get your need . I suggest to see if this one here is meet your needs .
Imad Habash
0 Me gusta
