slow selection
slow selection
No aplicable
We just setup a new network printer. When selecting the printer it takes a long time to finish thinking before i can click apply. This happens every time and we have a lot of drawings. This adds up at the end of the day. I understand that it is waiting for an acknowledgment from the printer to see if it is online. Is there a way to turn this acknowledgment process off so that it responds instantly. The windows spool will alarm if there is an issue.
0 Me gusta
Responder
322 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Not enough information, and I'm not sure this is an AutoCAD fix either. Is your I.T. working on a solution too?
What printer did you install?
What is your server network?
What is your PC's OS?
Your AutoCAD version?
How is your PC connected to the printer?
Does the printer have a unique IP address?
Are you trying to print to the network/system driver, or a PC3 file?
Did you remember to remove all traces of the old/removed printer from AutoCAD's search path? And your Windows printer options?
And what happens if you install that printer driver on your PC and plot to it? As a test of course.
0 Me gusta
No aplicable
You may be right, I just tried it on another software with the same results.
What printer did you install? Konica Minolta bizhub c554e using pharos printing server
What is your PC's OS? windows 7 64bit
Your AutoCAD version? 2014
How is your PC connected to the printer? network
Are you trying to print to the network/system driver, or a PC3 file? system driver
Did you remember to remove all traces of the old/removed printer from AutoCAD's search path? And your Windows printer options? yes
I will post this question on a windows sight: "is it possible to turn off "printer online acknowledment"?
0 Me gusta
