SLICE of 3D to generate Cross Section, SLICE not asking for Start Point of SLICING Plane
DM2-fire
DM2-fire
About a month ago i learned about SLICE while trying to figure out how to generate a cross section of an electrical panel.  I was able to generate the cross section, but can't figure out what I did with those drawings and now i've got to start over.
My steps are (I'm pretty sure this is what I did last time too...and it worked then, but not now):
a) SLICE
[SLICE responds with: "Select objects to Slice"]
b) I select the objects
[SLICE responds with: "Select objects to slice: Specify opposite corner: 62 found"]
When I press ENTER, I'm expecting SLICE to respond with "Specify starting point of Slicing Plane or...", but it doesn't do that.
Patchy
What you have there is a block.
Explode it then Slice
DM2-fire
Ok...that worked.
