SLDPRT to autocad conversion problem
inflameWBW5X
inflameWBW5X
I've imported a part into Autocad 2017 student and want to do some modifications to it before 3D printing it.
I had to scale the part which seemed to work ok, but I tried to create a hole in the part by placing a 3d box then subtracting it. That doesn't work, it leaves behind remnants of the original part.
What do I do to make the imported part fully editable ?
0 Me gusta
Responder
Soluciones aceptadas (1)
760 Vistas
15 Respuestas
Respuestas (15)
pendean
Community Legend
Community Legend
Share your actual DWG file please.
inflameWBW5X
Yep, sure.Here's the file after importing.
0 Me gusta
vinodkl
Use the command "XPLODE" on the part to make it editable.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
inflameWBW5X
XPLODE works to separate the parts, but 3d union won't put them back together.
I noticed that right after import if the first thing I try to do is subtract from it, Autocad thinks it's not a solid part.
0 Me gusta
vinodkl
Instead of using subtract, try drawing a rectangle using command " REC" of defined mesurement on the side where you want the hole and use the command "PRESSPULL" to remove the part and then delete the rectangle which would be no longer needed.
inflameWBW5X
Do you mean use presspull to drag it through the part ?
0 Me gusta
vinodkl
Yes drag it through the part to remove that portion.
inflameWBW5X
Nah that doesn't either.
I think I need some way to turn the object into a 3d solid that Autocad understands.
The original part is in a downloadable zip file from here : https://www.thingiverse.com/thing:336948/files
It contains the solidworks files. If you want to try it to see if you can work out how to covert the file, just click on "Thing files". This one is the Relaybox top.
0 Me gusta
vinodkl
Check this
https://knowledge.autodesk.com/community/screencast/3d19124c-aade-457b-b379-b10ca413ead6
inflameWBW5X
WOW that screen cast thing is crazy. I love it. Is that for on this site only or is it a stand alone thing ?
I watched through the video but I'll have to study it tonight to see exactly what you've done and I'll get back to you.
Thanks for going to all that trouble for me.
0 Me gusta
vinodkl
>>Is that for on this site only or is it a stand alone thing ?<<
Its actually software developed by Autodesk. check more about it : click here
>>Thanks for going to all that trouble for me.<<
No problem phil :cara_sonriente_con_la_boca_abierta:
inflameWBW5X
0 Me gusta
vinodkl
Solución aceptada
I guess you didn't explode the block reference to convert to 3d solid.
Please use the command " XPLODE" at the start itself.
inflameWBW5X
Oh crikey ! Yes I guess I missed that somehow, and it worked !
Perfect thanks.  I'll be able to continue my project now.
So how come presspull works but inserting a box then deleting it doesn't ?
0 Me gusta
vinodkl
You could also use the SUBTRACT and it works the same. I guess you didn't XPLODE before starting to SUBTRACT, that's why you were not able to subtract.
0 Me gusta
