.SKD file to DWG - Autosketch to AutoCAD
Hi
I am hoping that a genius might be able to offer some assistance.
I have a couple of files created in Autosketch which need to be saved / converted into AutoCAD.
Sadly these files are no longer able to be accessed as I no longer have the machine (or the copy of the software) these were created on some years ago. I understand the software is no longer supported. Is there a solution or someone who could help?
Many thanks
Tom
ennujozlagam
hello, refer to these LINK and  LINK and see if helps. thanks
Thank you for your reply.
Perhaps I require a 64-bit version as the software is not compatible with my version of Windows.
Is this possible?
Many thanks for your help!
Alfred.NESWADBA
have you tried to install the 32bit version on your 64bit system?
If that really does not work you might create a virtual system (like >>>VirtualBox<<<) with a 32bit OS and install this SW in that system.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I have an older version of AutoSketch installed and was able to open your files and save them as 2007 format dwgs. I hope this helps.
John Vellek
khwanchirakhan
Community Visitor
Community Visitor
Hi there,
Do you still have that software,
can you also convert my file to DWG?
