Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Simple linetype (.lin) with lines and slashes
scmallory
scmallory
Is it possible to make a simple linetype (.lin) with lines and slashes "/". I don't want it to include a shape file because this means it has to be loaded into everyones autocad and/or dwg's.
I believe the sequence would be
*SLASH,Slash ____//____//____//____//____//_
A,.5,-.2,["//",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.05],-.25
However the "/" do not appear.
Thanks for the help!
Kent1Cooper
They do for me:
What is the font assigned to your STANDARD Text Style?  And does that Style have a fixed height?  It should have a defined height of 0 if it's to be used in a linetype definition.
EDIT:  The above image is with ARIAL.ttf as the assigned font [the default in newer versions].  Here's what it looks like with TXT.shx [the default in older versions]:
Kent Cooper, AIA
scmallory
Glad to see it works for someone!
My standard text style does not have an assigned text height.
I have also attached a picture of what the linetype looks like
scmallory
I tested it in a new dwg and it worked so I'll have to assess the reasonings why its not working in my other drawing. Thanks for your help @Kent1Cooper
scmallory
I reloaded the linetype and got it to work.
