Anuncios
silhouette edges
jackshield
silhouette edges
jackshield
cannot get silhouette edges to go away in plot, what am i missing?
0 Me gusta
Responder
1.529 Vistas
3 Respuestas
Respuestas (3)
leeminardi
Change DISPSILH from 0 to 1, change the Visualstyle for each of the viewports from Hidden to 2D Wireframe and that should do it.
~Lee
lee.minardi
0 Me gusta
No aplicable
One downfall with that is it forces plot to be raster (at least, it does for me if I set silhouette edges to have width 3, the only way I've found to force the mesh lines not to show... If I leave silhouette line width at 1 it's vector, but the full mesh shows) - not tremendous when you have perfect lines otherwise, and are used to zooming in on PDFs... Do you know if there's another parameter that controls raster vs vector pdf plot?
0 Me gusta
ChicagoLooper
You applied a HIDDEN Visual Style to your viewport. You should make your viewport visual style 2D Wireframe and apply HIDDEN to the viewport Properties in the Properties Palette.
  1. Change the visual style of each VP from Hidden to 2D Wireframe.
  2. While on your layout tab, select the VP so the description at the top of the Properties Palette changes from No Selection to Viewport.
  3. In the Properties Palette, under MISC section, change 'Shade Plot' from Hidden to As Displayed.
Go to print preview.
Alternatively:
  1. Make the visual style for each VP HIDDEN.
  2. Select a VP so 'viewport' appears at the top of Properties Palette.
  3. Under Misc section of Prop Palette, make Shade Plot WIREFRAME.
Chicagolooper
0 Me gusta
