Showing dimensions as feet and inches
Hey all,
Just as the subject suggests, I am having trouble figuring out how to show dimensions as 40'-6" for example. Does anyone know how to do this?
Thanks!
Kent1Cooper
Get into the Dimension Style Manager, pick a Style, Modify..., Primary Units tab, Linear Dimensions area, Unit format list, pull down and pick Engineering or Architectural [depending on whether you want partial inches as decimals or fractions].  Or set the DIMLUNIT System Variable to 3 or 4.  And by all means, read up on units of measure in Help.
Kent Cooper, AIA
caterina_damicoY7QSX
Community Visitor
Community Visitor
that is for autocad. what about autocad web?
Kent1Cooper
I have no idea, but surely it has some way of setting the Units format in Dimension text.  What have you found in Help?
Kent Cooper, AIA
Community Visitor
Community Visitor
Nothing. I discovered that you can open an an acad imperial file. But if you have created a field and just changed the units to architecture I'll will gust give you the decimal dimensions. Frustrating!
