Show zero value in table
This widget could not be displayed.
When I close and reopen a drawing, the value of zero is shown in cells of a table which was empty before closing.
Replies (9)
imadHabash
would you please attache that table here as CAD file?
Imad Habash
 Please find attached table with zero values when I reopened it. This does not happen for my colleagues. Actually when they use the same format and close it open it many times this does not happen to them. But when they open my files they have the same issue as me.
Thanks,Hajmirzaali
Alfred.NESWADBA
Nothing attached.
Please don't use the answer option in your mail system. Instead use your Internet browser and the "Reply" option here to answer and to attach file(s).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Please find attached dwg.
Hajmirzaali
Alfred.NESWADBA
I have attached a drawing, which is your's opened, the "0" values are removed" and saved.
Do you see the "0" values again in the table?
- alfred -
Alfred NESWADBA
I just opened it and it looks as attached screen shot.
Alfred.NESWADBA
So the initial question:
...does not appear with my drawing.
I deleted the "0" and these fields stay empty, even when closing and reopening the drawing.
That brings me to the questions:
  • which version of AutoCAD do you have
  • do you have any apps on top of AutoCAD
  • how do you delete the zeros in the table?
- alfred -
Alfred NESWADBA
I'm using CAD 2014. I have no app (just I have Autodesk 360).
As I told you it does not happen for my colleagues as well as you. Even for me it is good 4~5times of opening of the file and after that the zeros come back. When I delete them, again it will back after next 7~8 opens and saves.
I did not touch or delete anything from your file and just I opened it and I saw the Zeros.
For deleting I select cell by mouse and push on delete button on keyboard.
I am experiencing the same issue with autocad table. every time I open drawing with table autocad populate each empty cell with 0. Can someone help on this issue
