AutoCAD Forum
Shift key will not toggle ortho mode
35 REPLIES 35
Message 1 of 36
20491 Views, 35 Replies
I cannot get the shift key to toggle ortho mode. I have turn on and off temp overrides and it still didn't work. I've seen this problem a couple places with no solution. Can this be fixed? Am I missing something?
35 REPLIES 35
Message 21 of 36
Bimzo2000
in reply to: fridaJE59J
Yes! Did you find a solution? It drives me mad. It is really not acceptable that the modst basic workflow doesn't work after x years and a two key solution should be found to fix something that is just wrong.
Message 22 of 36
ireneAZESA
in reply to: Bimzo2000
Hi
The command is - tempoverides - then type 1 and press enter
Message 23 of 36
Bimzo2000
in reply to: ireneAZESA
unfortunately the overrides-fix doesn't work for me...(yes, I did restart). I also do not see an "ioption" as some suggested.
Message 24 of 36
fakhrulirfan1
still not working on my 2021 cad. any tip for solution?
Message 25 of 36
pendean
in reply to: fakhrulirfan1
Are you on a laptop, or desktop?
wireless keyboard or wired?
Are you aware there is a 1+second delay before that comes on so you have to wait for it?
AutoCAD2021 is an old program today in December2024: what changed with your setup or PC when it broke or stopped working? Something did, can you find out and share?
Message 26 of 36
ireneAZESA
in reply to: pendean
It stopped working after Autocad would crash and had to be reset. I am now
using 2024 and it works fine now.
Message 27 of 36
fakhrulirfan1
autocad 2021 using laptop high spec. not delay anymore. just one prob i
have. before that i used autocad on acer laptop and button shift can
use be on off ortho. now i changed using asus with the same file autocad
but shift button does not function as on off ortho.U know how to solve it?
Message 28 of 36
fakhrulirfan1
if u dont mide can u share file autocad 2024 to me sir. big prob to me if shift button not function as on off ortho.😩
Message 29 of 36
ireneAZESA
Autocad programs are not shareable. There is a command inside the program
that toggles using the Shift key is: Command-tempoverrides. 0 is off and 1
is on
Message 30 of 36
fakhrulirfan1
i have try this tempoverrides 0&1 but shift ortho still not working
Message 31 of 36
ireneAZESA
I am sorry then I cannot help you. Perhaps you can open a support case with Autocad direct. They are very responsive to this. It could also be your mouse or keyboard. Often F keys have many different uses.
Message 32 of 36
CRAIGNEWICKS3779
try entering TEMPOVERIDES into the command line and if it is set to (0) change it to (1).
this fixed mine.
Message 33 of 36
CRAIGNEWICKS3779
type TEMPOVERIDES into the command line and if it is set to (0) change it to (1).
this fixed my problem.
Message 34 of 36
delfinataylor
The same happens to me, it used to work perfectly until it suddenly didn't anymore, and I'll use it the same way as you mention. I'm using autocad 2024 in a lenovo legion laptop. What is bizarre is that it used to work just fine, and I can't get it to connect it back in the settings part.
Message 35 of 36
delfinataylor
This Tempoverrides command worked perfectly! changed it from 0 to 1. Don't know if it changed anything else but now the shift key is working! Thanks!
Message 36 of 36
akkocmstf
What I tried;
"tempoverides to 1" did not work
Resetting the settings did not work
Reinstalling windows did not work
Turning off windows hotkeys didn't work
turning off keyboard shortcuts in accessibility options didn't work
There is no option called SHIFT + LEFT CLICK IMAGE under options in autocad.
Changing the keyboard shortcut in cui directly did not work
My computer is monster abra a7 v14.6, I use autocad 2025 on windows 11. Before this, the "shift" key was working when I was using AutoCAD 2023 on a Dell computer in Windows 10 (note: I installed AutoCAD 2023 on my new computer, but it did not work)
The method that works for me
There are 2 "toogle ortho" methods in the keyboard shortcut. In the cui settings, copy the "macro" of one of them then delete them both. Then paste the code you copied into another keyboard shortcut you don't use. Set the keyboard shortcut to "shift+<".
Apply the changes and close the "cui" menu.
IMPORTANT! When you try "shift+<" you have to hold it down for a while. After 1 second the ortho mode changes. When you release "shift+<" it returns to its previous state without waiting.
the macro:
^P'_.orthomode $M=$(if,$(and,$(getvar,orthomode),1),$(-,$(getvar,orthomode),1),$(+,$(getvar,orthomode),1))
AutoCAD Inside the Factory
