Sheetset Publish to PDF - Scale
Helcalian
Helcalian
Good morning all,
When I publish a Sheetset by right clicking on it and selecting "Publish to PDF" it scales the drawings down by 50% while keeping the page size correct. If I instead use Publish with Dialog Box and select PDF it works fine. Attached are the PDFs.
Is there some hidden setting somewhere that I'm missing that could be causing this?
Autocad Architecture 2020 btw...
Any help would be great.
jggerth
The best way to handle publishing is using Named Pagesetups, keep the one you want to use current,  or choose them in the  Publish to dialog
Helcalian
Sheetset and dwgs attached for referenece incase there's some setting imbedded in them.
Valentin_CAD
Hello, Everything works on my end. Does it happen on all drawings?
Do you get the same results doing it from the "Publish Dialog Box..." instead of "Publish to PDF".
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Helcalian
Publish to Dialog Box works fine.
The problem has been happening to me on all sheetsets old and new. I used to be on 2017 and publish to pdf worked all the time. To my knowledge, it doesn't happen to anyone else running 2020 in the office.
Valentin_CAD
I would do a Repair:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Emilio Valentin
Helcalian
I spent some more time experimenting and it seems to be something in my Profile. I changed it back to one of the default profiles and its Publishes to PDF correctly without having to use the dialog box. If I can pinpoint the issue I'll update you, but I'll probably just make a new profile for now.
