Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Sheet Views Tab showing sheets out of order
tim312324
tim312324
I have a sheet set and the Sheet List tab is in the correct order (A100s, A200s, A300s, etc).  When I navigate to the Sheet Views tab, the sheets are out of order.  This has never happened to me before and makes it very difficult to find sheet views quickly.  Sheet Views is already difficult to navigate as there is no "collapse all" option.  Does anybody have any tips or experience with this issue?
What Sheet List tab shows:
What Sheet Views tab shows:
Cadologist
I tested this in AutoCAD 2023, you can hold down the left mouse button and 'drag-drop' the subset tabs to the order of your preference. As a suggestion, collapse all subsets first as you may inadvertently drop a subset into a different subset when reordering.
Chad Franklin
tim312324
Hi, thanks for your response.
I am able to move sheets and subsets around no problem in Sheet List tab, that is not the issue.  The issue is that I am unable to do so in Sheet Views tab (there are no subsets in Sheet Views) and the list of sheets in Sheet Views tab is showing up in a random order.
Again, in Sheet Views tab, I cannot drag and drop the sheets to change the order.  I would typically not ever need to do that because until now, all my projects in SSM correctly ordered the sheets in Sheet Views.
What determines the order of sheets in the Sheet Views tab?
miah_mcbride
I've submitted 4 Help tickets for this now and still don't have a fix or an answer from Autodesk... Has anyone figured out how to fix this bug?
