Sheet set scale ######
michael.shannonHBLAB
When making a PDF of my sheet set the scale is correct on the sheet but shows up as ###### on the PDF.
Scale is set to 1:1 on the page set up.
pendean
Community Legend
Community Legend
#### almost always means that FIELD's source for information was not available or missing.
Or in a table cell the cell width is too narrow to show that information that FIELD did find.
It shows up on the sheet and in the preview but does not show up on the PDF. So it knows what the information is. Is there a way to edit the block used for sheet set drawings tags?
pendean
Community Legend
Community Legend
2michael.shannonHBLAB which PDF driver are you using?
And can you test with others?
I'm using the AutoCAD PDF (general documentation) to print it and Probably Microsoft edge to view it (it is a student's problem)
JTBWorld
What version of AutoCAD?
Do you use background plotting/publishing?
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Yes we do. I found it to be an issue with the PDF reader.
