Anuncios
Sheet Set "Source File" not following Copied Drawing file.
jarredmonday
jarredmonday
When copying the master .dwg file WITH the .dst file into a new folder, the .dst "Source File" is linked to the master .dwg. I expected the "source file" to be updated when both files are copied together. Is there a setting in the SSM I am missing to be able to update the source file location ?
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
0 Me gusta
Responder
Soluciones aceptadas (1)
2.381 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
.DST are very specific to creation location: simply copying them elsewhere in Windows File Explorer does not auto-update them, and there is no SSM setting to make them so. Sorry.
0 Me gusta
jarredmonday
Solución aceptada
I figured it out. To have the .DST file follow the copied file and not be linked to the original master file is to NOT rename the new .DWG file. As long as the two files are moved or copied together, the sheet set will be linked to the .DWG file.
For me this shouldn't be an issues since we have a specific subfolder for each client and is not necessary to rename the cad files.
0 Me gusta
