Sheet set only works on one network computer
06:11 AM
- Mute
- Permalink
- Report
Hi, I have created a sheet set that using "page setup overrides" will print either a hard copy on a network printer, pdf or dwf. My sheet set is saved on the network and the template.dwt with the page setups is also saved on the network. The sheet set works perfectly for me but when someone else in the office tries to use it the print to pdf option fails to print, the print to dwf option prints the first few layouts in the sheet set and the print hardcopy prints successfully. I'm not sure what the problem could be, we are all using the default Autocad DWF6 ePlot.pc3 and DWG to PDF.pc3 that are saved locally. I created the sheet set using Autocad 2012. If anyone could help me out I would appreciate it!
Link copied
