How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Ever since installing 2023, I have constantly had the issue of my sheet set manager disappearing. Once it goes, I have to voodoo my way through the CUI dialog to try and get it to come back. Sometimes it does, sometimes it doesn't. I have even reformatted my pc, installed only Autocad 2023 and it still happens. I found if I set my workspace file to read only, after a fresh install, it stops happening. AutoCad is doing something that is corrupting this file. Please fix this. Year after year autodesk insists on pushing out new features and completely ignores work flow breaking issues. And yes, I've tried every solution offered on the net. It seems like im not the only one experiencing this.
@mlfgale ,
We all understand your frustration.
Although you have "tried every solution offered on the net", here are some links that may help others with similar issues:
Checking the default settings of all secondary windows may also help:
You can also send your Feedback to Autodesk:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
How to buy
Type a product name
