Sheet Set Manager PDF error
ida_burrell
ida_burrell
AutoCAD 2017 for Sheet Set Manager is giving us PDF errors. We've setup template to A1 but it prints to the wrong size. See attached sample of print errorA1 print.JPG
0 Me gusta
Responder
Soluciones aceptadas (2)
2.305 Vistas
8 Respuestas
Respuestas (8)
pendean
Community Legend
Community Legend
Your "template" may be incorrectly set: show up, post a DWG file with that pagesetup in it ready to go.
0 Me gusta
ida_burrell
Our DWG template is set up correctly because it works with 2014 version. we don't get the error in 2014 only on 2017. The only thing I can think of is overwrite 2017 PC3 file and use the 2014.
0 Me gusta
pendean
Community Legend
Community Legend
Your screenshot says otherwise but if that works for you go ahead and try it.
0 Me gusta
neaton
Did using the 2014.pc3 file work? You may have made changes to the out of the box .pc3 file you don't remember doing as most .pc3 files are quite a few years old and have never changed. My 2018 out of the box DWG To PDF.pc3 file is dated 10/2014,
Lots of system variable settings could be affecting this and some default settings changed between 2014 and 2017. I agree with @pendean something is different.
0 Me gusta
ida_burrell
Unfortunately it didn't work. So we're back to old system of publish plot for now if we use 2017 version. Some of us are using 2014 for now to use the Sheet Set Manager. It's faster when it comes to publish plot plus etransmit without having the need to keep adding drawings everytime there's a submission.
Thank you for your help
0 Me gusta
neaton
I think someone here can help if you post a drawing or your template. You can strip it of everything except your titleblock which you could also strip clean of info you don't want to share, too.
What version of AutoCAD are you using? Any verticals (Architecture, Civil 3D)? Are all service packs and updates installed?
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Are you under the impression each and every AutOCAD2017 user on the planet cannot publish like they did in 2014 as well? Or is there something else going on?
We cannot help you without your file(s) since we all Publish all day long in R2017 with no issues.
0 Me gusta
Cadologist
Solución aceptada
To confirm, are you still using the AutoCAD PDF drivers from 2014? If so, they were updated in 2016 (pretty sure this is the version that the changes occurred in). We ran into a PDF issue on output, not related specifically to paper size but a batch plotting issue with Sheet Set Manager. We were using an older version of the PDF driver that comes with AutoCAD (stored on our network for all CAD users to access), which seems to have causes the issue. Driver's were updated (information below) and the PDF output worked again.
The 4 updated AutoCAD PDF drivers are shown below (FYI - there is no longer a DWG to PDF.pc3)
  • AutoCAD PDF (General Documentation).pc3
  • AutoCAD PDF (High Quality Print).pc3
  • AutoCAD PDF (Smallest File).pc3
  • AutoCAD PDF (Web and Mobile).pc3
As a suggestion.... take a copy of AutoCAD PDF (General Documentation).pc3 and RENAME it to DWG to PDF.pc3. Next, BACKUP and REPLACE the PDF AutoCAD driver you were previously using. Restart AutoCAD and try to print again using all the settings as they were prior.....
IMPORTANT NOTE: You need a copy of all (4) of the AutoCAD PDF drivers in your pathed plotting support folders. (Options --> Files --> Printer Support File Path --> Printer Configuration and Printer Description File Search Paths). Additionally, include a 5th PDF PC3 which is a copy of AutoCAD PDF (General Documentation).pc3 byt renamed to DWG to PDF.pc3). This ensures that your existing page setups will work and you won't need to recreate/update them for the revised PC3 "names". If the 4 default drivers are not present in your pathed folder, you may experience output issues (we did).
This solved our issues as the drivers needed to be updated to the revised versions. Good Luck, hopefully this helps and ultimately resolves your PDF output issues. Worth a try....
Chad Franklin
0 Me gusta
