Anuncios
Share fields between several dwg drawings
valotaire_emile
valotaire_emile
Is it possible to share fields between several DWG drawings.
When I change a part number the number changes on all other drawings.
0 Me gusta
Responder
Soluciones aceptadas (1)
319 Vistas
3 Respuestas
Respuestas (3)
apjones
I don't think fields can do this, but look into Rtext (Remote text). {Edit:  It is an Express tool}  It allows an external txt file to be referenced inside AutoCAD drawings.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
valotaire_emile
Is it possible to center the alignment of the RTEXT ?
0 Me gusta
JTBWorld
Solución aceptada
One way is to use the Sheet Set Manager and Custom Sheet Set properties.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
