Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Good morning. I work entirely in the ESRI environment and am responsible for mapping wetlands for the Wisconsin Department of Natural Resources. I do not have AutoCAD, but need to understand the export options available to the everyday AutoCAD user. I receive ground surveys containing wetland boundaries and I continually have issues working with .DWG files.
The first issue is the spatial information tag. It shows up as blank when I read the PROPERTIES of the .DWG file from within Arc Catalog and I have to ask the sender what coordinate system the data are in.
The second issue is the ESRI shapefile format. Can the average AutoCAD user export a .DWG file into the ESRI shapefile format? I have received a handful of files from AutoCAD users in the shapefile format and they import smoothly and I am wondering if I can simply request the files be sent in the shapefile file structure?
Is there a SAVE AS or an EXPORT AS option from within AutoCAD? Is it an add-on or extension to the software?
Thank you for you expertise and for lending an ear.
Calvin Lawrence
