AutoCAD Forum
Shade problem
1 REPLY 1
300 Views, 1 Reply
Shade problem
I have a question. I'm drawing in autocad 3d and i want my object shaded, but the only thing that is shaded are the corners of the object. How can you solve this problem?  this is how it looks, i was trying to do it with a youtube tutorial
1 REPLY 1
vinodkl
Hi @Anonymous
If I am not wrong, I think you didn't create a closed path or did not all join the lines to make it a closed path while using the command "EXTRUDE" and that's why it resulted in a surface than a solid.
Try to make the shape of the blade a closed path and then extrude it to create a solid object which would make it look like solid when you switch to "shaded" visual style🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Forma Design Contest
