Setup two extra mouse buttons
Message 1 of 10
Hi. I purchased new mouse (TeckNet M002) with 5 buttons.
My goal is to program two extra buttoms (pageUp and pageDown) so when I click pageUp AutoCad toggle osnap and when pageDown is pressed it toggle ortho.
Is there any way I can setup it in AutoCad?
In Customize User Interface i can only assigned F1-F12 and combinations of two keys for all commands in AutoCad. When i press pageUp or pageDown (or any other keyboard button) in assigned box it just stays empty.
Replies (9)
Message 2 of 10
-FDC-
You should install their drivers:
http://www.tecknet.co.uk/support/m021.html
Then you should be able to programm the buttons with their software.
Don't forget to restart autocad after changing the button layouts.
Message 3 of 10
I just plug in mouse and Windows 10 automatically download driver. Mouse is working fine. I install Mouse Manager from RealityRipple Software and programmm the buttons. One button for pageUp and other for pageDown. They work like i press pageUp and other for pageDown on keyboard.
The problem is that in Customize User Interface I cant setup shortcuts command with only one keyboard letter. In this case pageUp for toggle osnap and pageDown for toggle ortho. Only F1-F12 can be assigned
Message 4 of 10
-FDC-
The way I do it is through the Original mouse driver software.
I can assign F8 to any button I want.
Message 5 of 10
-FDC-
With the 3Dconnexion Cadmouse I can even choose the button behaviour for each programm.
I thought Logitech could do this as well but I can't find it.
Message 6 of 10
Interesting solution but I try to use these two buttons just for pageUp and Down. In this way i dont need setup button behaviour for each program.
In AutoCad I use pageUp and Down for two commands, and when Im in other program (word, excel, chrome, pdf reader.......or any other program) I can also use extra mouse buttons for scroll up or down in documents. In this way its very useful and user friendly.
Message 7 of 10
-FDC-
I am afraid it doesn't work that way.
Message 8 of 10
If it works in BricsCad, i dont known the reason why it shouldnt work in AutoCad.
Message 9 of 10
pendean
Community Legend
Community Legend
This is not BricsCAD: are you under the impression both software packages from rival software makers are somehow connected?
Or are you just advertising for BricsCAD over here 🙂
In AutoCAD, your mouse driver is used to do what you want, if the driver is able to do that.
Message 10 of 10
No advertising.
I just wont known is possible to setup AutoCad so when i press pageUp (it does not matter if it is pressed by keyboard or mouse) toggles osnap command is activated.
