setup error
setup error
setup error
Accepted solutions (3)
JoAnn_Hogan
Hi There and welcome to the community,
Please clean up your temp folder.
  1. Ensure all your programs has been closed
  2. Go to your run command, type in "%Temp%" and delete EVERYTHING in the folder.
Then attempt the installation again. Please let me know if this helps.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Thanks for your concern
but Unfortunately,faild solution
jessica.t
Hi @Anonymous!
Let's start from the top! Please perform a clean uninstall to remove any residual installation and download files. Then please re-download your software following these steps:
  • In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
  • In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
  • Turn off your personal firewall or VPN, if you use one.
  • Disable UAC
  • Close and reopen your preferred browser.
Let us know how it goes or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer.
Thanks!
Jessica Thrasher
ukdxb012
If Jessica's advice doesn't work, you could try the following suggestion here... http://forums.autodesk.com/t5/installation-licensing/firstrunthreadid/td-p/5364205
1- Create folder C:\Temp
2- Navigate to Control Panel/User Accounts/Change My Environment Variables
3- Change the value of both TMP and TEMP to C:\Temp (Default is %USERPROFILE%\AppData\Local\Temp)
But first i recommend following Jessica's steps. Let us know how you get on.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
